Помощь
HP LaserJet P1102w Power Plug Replacement
How to remove defective power plug. Either the prongs are bent or there is no power going to the unit.
  • Автор: Myles Nofsinger
  • Времени уйдёт: 15 - 20 мин.
  • Сложность: Средняя
These steps will show how to replace the power plug from the printer. This guide may be used if the prongs of the plug are broken or if a new power supply is needed all together.
Разделы
Инструменты
Шаг 1 Power Plug  ¶
The power plug will be held together with one Phillips screw 7mm and wire connection. The power plug will be held together with one Phillips screw 7mm and wire connection.
Шаг 1 Power Plug  ¶
  • The power plug will be held together with one Phillips screw 7mm and wire connection.
Шаг 2  ¶
Unplug wire connector and unscrew the Phillips 7mm screw with #1 Phillips screw driver. Unplug wire connector and unscrew the Phillips 7mm screw with #1 Phillips screw driver.
Шаг 2  ¶
  • Unplug wire connector and unscrew the Phillips 7mm screw with #1 Phillips screw driver.
Шаг 3  ¶
Apply pressure using spudger on top of the power plug to release it from metal housing. While doing that pull the power plug out. Apply pressure using spudger on top of the power plug to release it from metal housing. While doing that pull the power plug out. Apply pressure using spudger on top of the power plug to release it from metal housing. While doing that pull the power plug out.
Шаг 3  ¶
  • Apply pressure using spudger on top of the power plug to release it from metal housing. While doing that pull the power plug out.
