Помощь
Yuneec Breeze 4K Leg Replacement
This guide will teach you how to replace a leg on your Yuneec Breeze 4K Drone.
  • Автор: Wes Knutson
  • Времени уйдёт: 2 мин.
  • Сложность: Очень просто
If you are having issues landing your Yuneece Breeze 4K, it is probably due to a leg being broken or chipped. This guide shows you how to safety remove one of the legs and replace it with a new one. We have also provided a link for you that will show you where new replacement legs can be purchased.
Связанные запчасти
Шаг 1 Leg  ¶
Turn the drone over so the propellers are facing down. Pull the leg up so the leg is pointed up towards the ceiling.
Шаг 1 Leg  ¶
  • Turn the drone over so the propellers are facing down. Pull the leg up so the leg is pointed up towards the ceiling.
Шаг 2  ¶
Firmly grasp the leg so it is snug between your fingers. As you are grasping the leg, turn the leg counter clockwise about 80-90 degrees and pull up. This should take the leg out of its socket. Pull up so the leg is out of it's socket. Now you can put in the replacement leg.
Шаг 2  ¶
  • Firmly grasp the leg so it is snug between your fingers.
  • As you are grasping the leg, turn the leg counter clockwise about 80-90 degrees and pull up. This should take the leg out of its socket.
  • Pull up so the leg is out of it's socket. Now you can put in the replacement leg.
