Помощь
Lenovo Legion Y520-15IKBN Battery Replacement
This guide will explain in detail how to replace the battery in your Lenovo Legion Y520-15IKBN.
  • Автор: Naomi Williams
  • Времени уйдёт: 20 мин.
  • Сложность: Просто
If your laptop will not start up or stay charged you may need to replace the battery. To follow this guide you only need a plastic opening tool such as a spudger or credit card and a Phillips #00 screwdriver. It is not a difficult project and the hardest part will be prying the back piece off.
Инструменты
Шаг 1 Battery  ¶
Remove thirteen 6.5 mm screws from the bottom of the laptop using a Phillips #00 screwdriver. Remove thirteen 6.5 mm screws from the bottom of the laptop using a Phillips #00 screwdriver.
Шаг 1 Battery  ¶
  • Remove thirteen 6.5 mm screws from the bottom of the laptop using a Phillips #00 screwdriver.
Шаг 2  ¶
Flip the laptop on its side and use a spudger or a credit card to pry the bottom covering off. To get a better grip you may want to open the laptop slightly.
Шаг 2  ¶
  • Flip the laptop on its side and use a spudger or a credit card to pry the bottom covering off. To get a better grip you may want to open the laptop slightly.
  • The bottom piece will make popping noises as it is pulled from the laptop.
  • When reassembling make sure that the bottom piece clicks back into place on all sides of the laptop.
Шаг 3  ¶
The battery is a long black rectangle located near the bottom of the device. Use a Phillips #00 screwdriver to unscrew the four 4.0 mm screws holding the battery in place. Use a Phillips #00 screwdriver to unscrew the four 4.0 mm screws holding the battery in place.
Шаг 3  ¶
  • The battery is a long black rectangle located near the bottom of the device.
  • Use a Phillips #00 screwdriver to unscrew the four 4.0 mm screws holding the battery in place.
Шаг 4  ¶
There is a small bundle of wires held together with black tape located on the top edge of the battery. Unplug it completely. When reassembling remember to plug these wires back into the port.
Шаг 4  ¶
  • There is a small bundle of wires held together with black tape located on the top edge of the battery. Unplug it completely.
  • When reassembling remember to plug these wires back into the port.
  • When removing the bundle it may feel fragile but don't be afraid to give it a tug.
Шаг 5  ¶
Lift the battery out of the laptop body.
Шаг 5  ¶
  • Lift the battery out of the laptop body.
