Помощь
Altec Lansing VersA Smart Volume Button Board Replacement
This guide shows how to access and remove the daughterboard in your Altec Lansing VersA Smart.
  • Автор: Rachael Hopp
  • Времени уйдёт: 9 - 10 мин.
  • Сложность: Средняя
If you are having issues controlling the volume on your device, this guide will show you how to remove and replace the daughterboard that connects to the volume and microphone buttons.
Разделы
Инструменты
Инструменты (продолжение)
Шаг 1 Volume Button Board  ¶
Orient speaker so volume buttons are facing up. Remove rubber button piece using the blue plastic opening tool.
  • Orient speaker so volume buttons are facing up.
  • Remove rubber button piece using the blue plastic opening tool.
Шаг 2  ¶
Remove the four 9mm screws using the Torx T5 screwdriver. Remove the four 9mm screws using the Torx T5 screwdriver.
Шаг 2  ¶
  • Remove the four 9mm screws using the Torx T5 screwdriver.
Шаг 3  ¶
Once screws are removed, remove the plastic covering piece. Remove the rubber piece below the plactic covering piece to expose the daughterboard.
Шаг 3  ¶
  • Once screws are removed, remove the plastic covering piece.
  • Remove the rubber piece below the plactic covering piece to expose the daughterboard.
Шаг 4  ¶
Orient speaker on its side with volume buttons facing away from you and Bluetooth and power buttons on the right. Detach the wiring, located in the upper middle section of the motherboard.
Шаг 4  ¶
  • Orient speaker on its side with volume buttons facing away from you and Bluetooth and power buttons on the right.
  • Detach the wiring, located in the upper middle section of the motherboard.
  • Remove daughterboard piece from opening in the top of the speaker.
