Помощь
HP LaserJet P1102w Left Side Panel Replacement
How to take off the plastic housing of the printer to get to the internals.
  • Автор: Jerome Etten
  • Времени уйдёт: 10 - 15 мин.
  • Сложность: Средняя
These steps will show how to replace the left side panel from the printer. This prerequisite guide will be used for the power plug removal, motherboard removal, and half of the drive belt removal guides.
Инструменты
Шаг 1 Left Side Panel  ¶
Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown. Pry carefully to not break any plastic. Pry carefully to not break any plastic.
  • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
  • Pry carefully to not break any plastic.
Шаг 2  ¶
Now that the pry points are free lift up the front panel. Now that the pry points are free lift up the front panel.
Шаг 2  ¶
  • Now that the pry points are free lift up the front panel.
Шаг 3  ¶
Unscrew the #1 Phillips screw 6mm on the back of the printer. Unscrew the #1 Phillips screw 6mm on the back of the printer.
Шаг 3  ¶
  • Unscrew the #1 Phillips screw 6mm on the back of the printer.
Шаг 4  ¶
Using the plastic spudger, remove the button housing from the top left of printer. Pry carefully to not break any plastic. Pry carefully to not break any plastic.
Шаг 4  ¶
  • Using the plastic spudger, remove the button housing from the top left of printer.
Шаг 5  ¶
Once the housing is removed, remove the three buttons. Once the housing is removed, remove the three buttons.
Шаг 5  ¶
  • Once the housing is removed, remove the three buttons.
Шаг 6  ¶
Use the plastic spudger to remove the side panel. There are three main prying points as shown. Pry carefully to not break any plastic. Pry carefully to not break any plastic.
Шаг 6  ¶
  • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
Шаг 7  ¶
With all pry points free, remove the side panel. With all pry points free, remove the side panel.
Шаг 7  ¶
  • With all pry points free, remove the side panel.
