Помощь
Harman Kardon Invoke Service Port Replacement
Граммар-наци
Граммар-наци
Разбуди в себе учителя английского, помогая улучшить грамматику этого руководства!
If your Invoke is not connecting to your computer in order to be serviced, there might be a problem with the service port and should be replaced.
  • Автор: Angel A. Grageda
  • Времени уйдёт: 10 мин.
  • Сложность: Просто
If your Invoke is not connecting to your computer in order to be serviced, there might be a problem with the service port and should be replaced. For this replacement you will need a metal spudger and a #10 Torx screwdriver.
Инструменты
Шаг 1 Remove the rubber base  ¶
Use a metal spudger to remove the rubber bottom. Use a metal spudger to remove the rubber bottom.
  • Use a metal spudger to remove the rubber bottom.
Шаг 2 Remove the base screws  ¶
Use a #10 Torx screwdriver to remove four 14 mm screws. Use a #10 Torx screwdriver to remove four 14 mm screws.
  • Use a #10 Torx screwdriver to remove four 14 mm screws.
Шаг 3 Remove the base  ¶
Firmly grip the bottom and wiggle upwards to remove the base. Firmly grip the bottom and wiggle upwards to remove the base.
  • Firmly grip the bottom and wiggle upwards to remove the base.
Шаг 4 Removing the board  ¶
Use a #10 Torx screwdriver to remove two 10 mm screws from board attached to ports. Pull board up lightly. Pull board up lightly.
  • Use a #10 Torx screwdriver to remove two 10 mm screws from board attached to ports.
  • Pull board up lightly.
Шаг 5 Disconnect the board  ¶
Pull cable to disconnect board from device. For replacement of service port, you will have to replace whole board that the port is attached to.
  • Pull cable to disconnect board from device.
  • For replacement of service port, you will have to replace whole board that the port is attached to.
