Помощь
HP Envy x360 m6-aq005dx Motherboard Replacement
Use this guide to remove or replace the motherboard of your HP Envy x360 m6-aq005dx.
  • Автор: Bradley Braganza
  • Времени уйдёт: 10 - 15 мин.
  • Сложность: Средняя
The motherboard is the main circuit board found in a laptop. It manages the communication between crucial electronic components that allow your computer to function. This guide will describe how to remove and replace the motherboard for HP Envy x360m6-aq005dx
Разделы
Инструменты
Инструменты (продолжение)
Шаг 1 Motherboard  ¶
Use a JIS #1 screwdriver to remove the 4.7mm screws from the indicated positions. Use the JIS #1 screwdriver to remove the 7.7mm screws from the indicated positions.
Шаг 1 Motherboard  ¶
  • Use a JIS #1 screwdriver to remove the 4.7mm screws from the indicated positions.
  • Use the JIS #1 screwdriver to remove the 7.7mm screws from the indicated positions.
  • Use the JIS #1 screwdriver to remove the 4.4mm screws from the indicated positions.
Шаг 2  ¶
Using your hand, lift the screen hinge located in the top left corner. This will allow for easier removal of the motherboard.
Шаг 2  ¶
  • Using your hand, lift the screen hinge located in the top left corner. This will allow for easier removal of the motherboard.
Шаг 3  ¶
Flip the indicated colored latches with iFixit Opening Tools, then use tweezers to release the cables attached to the motherboard by gently pulling backward. Use the pointed tweezer  to release the plug-in connectors my gently gripping the plug and pulling backwards. Use the pointed tweezer  to release the plug-in connectors my gently gripping the plug and pulling backwards.
Шаг 3  ¶
  • Flip the indicated colored latches with iFixit Opening Tools, then use tweezers to release the cables attached to the motherboard by gently pulling backward.
  • Use the pointed tweezer to release the plug-in connectors my gently gripping the plug and pulling backwards.
Шаг 4  ¶
Using your hand, lift and pull the motherboard from inside your computer. Using your hand, lift and pull the motherboard from inside your computer. Using your hand, lift and pull the motherboard from inside your computer.
Шаг 4  ¶
  • Using your hand, lift and pull the motherboard from inside your computer.
