Помощь
Sony Ericsson w600i LCD Replacement
Лучше введение
Лучше введение
Улучши это руководство, заполнив или отредактировав его.
Replacing a faded, broken, or otherwise malfunctioning LCD display.
  • Автор: Beau Blanchard
  • Времени уйдёт: 15 - 20 мин.
  • Сложность: Средняя
Разделы
Шаг 1 LCD Replacement  ¶
The LCD display is connected to the device with a small flex cable. To release the cable, flip the small handle on the connector to an upright position. The LCD display is connected to the device with a small flex cable. To release the cable, flip the small handle on the connector to an upright position.
  • The LCD display is connected to the device with a small flex cable. To release the cable, flip the small handle on the connector to an upright position.
Шаг 2  ¶
Gently pull the flex cable downwards with a pair of tweezers. Gently pull the flex cable downwards with a pair of tweezers.
Шаг 2  ¶
  • Gently pull the flex cable downwards with a pair of tweezers.
Шаг 3  ¶
Gently separate the side button component from the inner casing. It is attached with adhesive. Gently pull the front button component away from the inner casing slightly. It does not need to be removed.
Шаг 3  ¶
  • Gently separate the side button component from the inner casing. It is attached with adhesive.
  • Gently pull the front button component away from the inner casing slightly. It does not need to be removed.
Шаг 4  ¶
Remove the LCD screen by its white housing, pulling the flex cable through the slot from the other side of the casing.
Шаг 4  ¶
  • Remove the LCD screen by its white housing, pulling the flex cable through the slot from the other side of the casing.
Шаг 5  ¶
The LCD has been removed! It can now be replaced with a functioning display.
Шаг 5  ¶
  • The LCD has been removed! It can now be replaced with a functioning display.
