Помощь
Canon EOS Rebel XS 35mm Bottom Cover Replacement
Недостающие детали
Недостающие детали
Некоторые детали этого руководства отсутствуют. Помогите пользователям добавив инструменты, уровнь трудности или количество необходимого время.
iFixit replacement guide for the bottom cover of the Canon EOS Rebel XS 35mm camera.
This is a necessary procedure for replacing the bottom cover of the Canon EOS Rebel XS 35mm camera.This guide details how to remove the bottom cover and put a a bottom cover back on, whether it's the same one now fixed, or a new one.
Шаг 1 Bottom Cover  ¶
Remove 6 screws using a PH000 Screwdriver.
  • Remove 6 screws using a PH000 Screwdriver.
  • Remove 1 (7mm) screw
  • Remove 5 (4mm) screws
Шаг 2  ¶
With your fingers, push on the bottom cover with a horizontal force until it clicks and separates.
Шаг 2  ¶
  • With your fingers, push on the bottom cover with a horizontal force until it clicks and separates.
Шаг 3  ¶
With tweezers - although you can also use your fingers - you may remove these 5 gears (shown with colored squares around them) and place them somewhere else for the time being. They fall out easily while you're working, so this will help you stay organized.
Шаг 3  ¶
  • With tweezers - although you can also use your fingers - you may remove these 5 gears (shown with colored squares around them) and place them somewhere else for the time being. They fall out easily while you're working, so this will help you stay organized.
