Помощь
Nikon Coolpix 775 Screen Replacement
This guide will walk you through how to remove the screen for the Nikon Coolpix 775.
  • Автор: Nick Meador
  • Времени уйдёт: 2 - 10 мин.
  • Сложность: Средняя
Did your cameras screen go black? This guide can help you walk through the removal of this LCD screen for the Nikon Coolpix 775.
Разделы
Шаг 1 Screen  ¶
Remove the orange ribbon cable from its connector by  firmly but gently pulling it. Remove the orange ribbon cable from its connector by  firmly but gently pulling it.
Шаг 1 Screen  ¶
  • Remove the orange ribbon cable from its connector by firmly but gently pulling it.
Шаг 2  ¶
Pull out the pink cable connector. If it's not coming loose, use a pair of needle nose pliers to get a good grip on the connector.
Шаг 2  ¶
  • Pull out the pink cable connector.
  • If it's not coming loose, use a pair of needle nose pliers to get a good grip on the connector.
Шаг 3  ¶
Grab the back of the screen and gently lift up. It is only held on by adhesive so it should come out relatively easy. It is only held on by adhesive so it should come out relatively easy.
Шаг 3  ¶
  • Grab the back of the screen and gently lift up.
  • It is only held on by adhesive so it should come out relatively easy.
