Помощь
Bluetrek Skin Teardown
Разбираем
Разбираем
Разбирая устройство, мы даём возможность изучить его изнутри. Статьи из серии «Разбираем» не стоит использовать как руководства по вскрытию девайса.
Инструкция участника сообщества
Мы благодарны участнику нашего сообщества за составление этой инструкции. Она не редактируется сотрудниками iFixit.
Today, we are taking apart a bluetooth headset by the name of Bluetrek Skin. Contrary to the name, there appears to be no epidermal tissue on this headset anywhere. In fact it seems to have more of a plastic exoskeleton. Truth in marketing out the window...
Инструменты
Шаг 1 Bluetrek Skin Teardown  ¶
It puts the lotion on its skin... Or else it gets the hose again. In the last photo, I'm removing the removable ear clip. Don't worry, it gets better. In the last photo, I'm removing the removable ear clip. Don't worry, it gets better.
  • It puts the lotion on its skin... Or else it gets the hose again.
  • In the last photo, I'm removing the removable ear clip. Don't worry, it gets better.
Шаг 2  ¶
Pretty simple here, just work a small blade around the seam to pop the latches. You could probably use a spudger, but I didn't have one. You could probably use a spudger, but I didn't have one.
Шаг 2  ¶
  • Pretty simple here, just work a small blade around the seam to pop the latches.
  • You could probably use a spudger, but I didn't have one.
Шаг 3  ¶
We're in! Nothing exciting on the underside of the top shell. Still no dermal tissue. Nothing exciting on the underside of the top shell. Still no dermal tissue.
Шаг 3  ¶
  • We're in!
  • Nothing exciting on the underside of the top shell. Still no dermal tissue.
Шаг 4  ¶
The whole board just lifts out.
Шаг 4  ¶
  • The whole board just lifts out.
Шаг 5  ¶
The microphone is held in with a bit of hot glue. Just push the rubber part covering the microphone from the outside and it'll pop right out. Just push the rubber part covering the microphone from the outside and it'll pop right out.
Шаг 5  ¶
  • The microphone is held in with a bit of hot glue.
  • Just push the rubber part covering the microphone from the outside and it'll pop right out.
Шаг 6  ¶
Sadly, the earpiece is a bit less willing to part with the casing.
Шаг 6  ¶
  • Sadly, the earpiece is a bit less willing to part with the casing.
  • I haven't figured out a way yet to get it out without breaking something, and I still want to use this headset.
Шаг 7  ¶
And we now present, a battery. There's a nice RoHS sticker there, suggesting it contains hazardous substances (couldn't possibly be referring to the combustibility of Li-ion batteries, could it?).  Better not open it.
Шаг 7  ¶
  • And we now present, a battery.
  • There's a nice RoHS sticker there, suggesting it contains hazardous substances (couldn't possibly be referring to the combustibility of Li-ion batteries, could it?). Better not open it.
  • The battery is held in place with a weak adhesive. Just pop it off with your fingers.
Шаг 8  ¶
And now, some obligatory close-ups of the circuit board. The identity of chip in the center of the board (second photo, in the red square) has eluded me for quite a while.  The logo appears to read "CSI" but it actually turns out to be "csr". Given the size and mounting, it's probably a BlueCore4 series (not sure of the exact model).
Шаг 8  ¶
  • And now, some obligatory close-ups of the circuit board.
  • The identity of chip in the center of the board (second photo, in the red square) has eluded me for quite a while. The logo appears to read "CSI" but it actually turns out to be "csr". Given the size and mounting, it's probably a BlueCore4 series (not sure of the exact model).
  • This one chip handles pretty much everything. It contains the radio, baseband, and microcontroller. It runs off 1.8V to 3.6V controlled by an integrated voltage regulator. It supports v2.0+ EDR and can coexist with nearby 802.11 (WiFi) networks. It can even work directly with up to 8Mbit flash memory (according to the specifications, given the 8x8mm size of the package (mind out of the gutter please), it's likely external to the chip).
  • There could be something under the board the main chip is mounted on, but I don't have a way to get to it.
  • There's a few mentions of Innovi on the board. According to LinkedIn, Innovi might be either Bluetrek's old name or their parent company.
Шаг 9  ¶
This was a lot easier to identify. It's an antenna.
Шаг 9  ¶
  • This was a lot easier to identify. It's an antenna.
  • It's a "Fractus Slim Reach Xtend™ Bluetooth Wireless Headset Antenna", designed to also support 802.11b/g/n (basically anything in the 2.4Ghz range). It is tiny, only 7x3x1mm. It's not a particularly efficient antenna (rated at >50% radiation efficiency), but it was probably chosen for size. It's still a good one, I can be on the side of the house opposite of my phone and still have good reception.
  • For only 1mm thicker, Bluetrek could have used the more efficient "Compact Reach Xtend™", with a radiation efficiency rating of >70%.
Шаг 10  ¶
Here is the (mostly) disassembled Bluetrek Skin headset.
Шаг 10  ¶
  • Here is the (mostly) disassembled Bluetrek Skin headset.
  • The Skin is a lie!
  • Everything just snaps back together.
