Помощь
Nintendo Wii U GamePad Analog Stick Replacement
Replace the analog stick.
  • Автор: Kim Arre
  • Времени уйдёт: 40 мин.
  • Сложность: Средняя
Use this guide to replace the analog stick in your Nintendo Wii U GamePad.
Шаг 1 Analog Stick  ¶
Take out the left and right shoulder buttons in the upper corners. Remove the ZR and ZL trigger buttons by lifting up and sliding outward.
  • Take out the left and right shoulder buttons in the upper corners.
  • Remove the ZR and ZL trigger buttons by lifting up and sliding outward.
Шаг 2  ¶
Remove the top rubber cover by pulling it off of its mounts to access one of the mounting screws. Remove the four 5.2mm Phillips #0 screws.
Шаг 2  ¶
  • Remove the top rubber cover by pulling it off of its mounts to access one of the mounting screws.
  • Remove the four 5.2mm Phillips #0 screws.
Шаг 3  ¶
Use a spudger to lift the tab which releases the blue ribbon cable. Remove the analog stick and button cover.
Шаг 3  ¶
  • Use a spudger to lift the tab which releases the blue ribbon cable.
  • Remove the analog stick and button cover.
Шаг 4  ¶
Use your thumb and push the connector towards the rightmost edge to disconnect the analog stick cable connector.
Шаг 4  ¶
  • Use your thumb and push the connector towards the rightmost edge to disconnect the analog stick cable connector.
Шаг 5  ¶
Remove the two 9.0mm Tri-wing Y0 screws. Lift out the analog stick.
Шаг 5  ¶
  • Remove the two 9.0mm Tri-wing Y0 screws.
  • Lift out the analog stick.
