Помощь
Nintendo DS Upper LCD Screen Replacement
Неправильные инструменты
Помогите улучшить эту инструкцию — пусть в кадре и в тексте будут правильные инструменты.
  • Автор: dnguye26
  • Времени уйдёт: 5 мин.
  • Сложность: Просто
The top LCD is easy to remove once the rest of the cover and circuit board have been taken out.
Разделы
Инструменты
Шаг 1 Top LCD Screen  ¶
Use a flathead screw driver or dental tool to remove rubber covers on screen. Then using a #00 screw driver remove the screws beneath. Then using a #00 screw driver remove the screws beneath.
  • Use a flathead screw driver or dental tool to remove rubber covers on screen.
  • Then using a #00 screw driver remove the screws beneath.
Шаг 2  ¶
Using a soft plastic tool, pry the edges of the plastic case apart at the seam. Using a soft plastic tool, pry the edges of the plastic case apart at the seam. Using a soft plastic tool, pry the edges of the plastic case apart at the seam.
Шаг 2  ¶
  • Using a soft plastic tool, pry the edges of the plastic case apart at the seam.
Шаг 3  ¶
Separate the top cover from the body. Using a Phillips #00 screwdriver, remove the screw holding the hinge cover in place. Remove the hinge cover and set it aside.
Шаг 3  ¶
  • Separate the top cover from the body.
  • Using a Phillips #00 screwdriver, remove the screw holding the hinge cover in place.
  • Remove the hinge cover and set it aside.
Шаг 4  ¶
Feed the ribbon cables and the Wifi pigtail cable through the opening in the hinge cover. Remove the yellow spacer, and set aside.
Шаг 4  ¶
  • Feed the ribbon cables and the Wifi pigtail cable through the opening in the hinge cover.
  • Remove the yellow spacer, and set aside.
Шаг 5  ¶
Using a Phillips #00 screwdriver, remove the two screws holding down the speaker circuit boards. Remove the two small circuit boards and set aside.
Шаг 5  ¶
  • Using a Phillips #00 screwdriver, remove the two screws holding down the speaker circuit boards.
  • Remove the two small circuit boards and set aside.
  • Be careful of the small red and black wires connecting the two circuit boards not to break them.
Шаг 6  ¶
Move the black lock on the two large ribbon cables up with a pry tool, and gently pull out the two ribbon cables. For the small ribbon cable, pull the lock downwards. Gently pull out the small ribbon cable from the connector.
Шаг 6  ¶
  • Move the black lock on the two large ribbon cables up with a pry tool, and gently pull out the two ribbon cables.
  • For the small ribbon cable, pull the lock downwards.
  • Gently pull out the small ribbon cable from the connector.
  • Set the two small circuit boards aside
  • Be careful not to damage the two delicate ribbon cables when removing them from the DS.
Шаг 7  ¶
Using a pry tool, gently lift the top screen out of the shell. Set the top screen aside
Шаг 7  ¶
  • Using a pry tool, gently lift the top screen out of the shell.
  • Set the top screen aside
