Помощь
Nokia 3120 Speaker Replacement
This guide shows how to disassemble the phone and install a speaker.
  • Автор: Pierre Tong
  • Сложность: Средняя
This guide will disassemble the phone's cover plate and key pad to reveal the interface in order to work on the phone's speaker. This guide requires a moderate amount of work as the small parts are tricky to remove.
Разделы
Шаг 1 Speaker  ¶
Once the cover plate has been removed, the existing keypad should be easily removed. Once the cover plate has been removed, the existing keypad should be easily removed.
Шаг 1 Speaker  ¶
  • Once the cover plate has been removed, the existing keypad should be easily removed.
Шаг 2  ¶
Once the keypad has been removed, unscrew the 6 exposed screws on the front of the phone. Once the keypad has been removed, unscrew the 6 exposed screws on the front of the phone.
Шаг 2  ¶
  • Once the keypad has been removed, unscrew the 6 exposed screws on the front of the phone.
Шаг 3  ¶
Once all the screws have been removed, the front part of the phone should be removable from the rest of the phone.
Шаг 3  ¶
  • Once all the screws have been removed, the front part of the phone should be removable from the rest of the phone.
Шаг 4  ¶
To remove the speaker from the phone, take a pencil or sharp object and poke the speaker free from the removed front part of the phone.
Шаг 4  ¶
  • To remove the speaker from the phone, take a pencil or sharp object and poke the speaker free from the removed front part of the phone.
  • To install a new speaker, simply place a new speaker in the same location and put the phone back together.
