Помощь
Toshiba Satellite L305-S5946 RAM Replacement
Буллеты!
Буллеты!
Использование примечания и разного цвета шрифта, в частности использование нумерации, поможет сделать это руководство более понятным!
Remove RAM from your Toshiba Satellite L305-S5946.
  • Автор: Michael Erberich
  • Времени уйдёт: 5 мин.
  • Сложность: Просто
Use this guide to replace or upgrade RAM cards in your Toshiba Satellite L305-S5946. Replacing your RAM cards will allow you to work with more programs. Doing this requires only removal of the battery as a precursor.
Разделы
Инструменты
Связанные запчасти
Шаг 1 RAM  ¶
Use a Phillips #1 screwdriver to turn the screw on the RAM cover.
Шаг 1 RAM  ¶
  • Use a Phillips #1 screwdriver to turn the screw on the RAM cover.
  • Turn the screw until you hear a click.
  • This is a captive panel screw and remains with the cover.
Шаг 2  ¶
Insert the plastic opening tool into the indent and lift to remove the RAM cover. This is a captive panel screw and remains with the cover.
Шаг 2  ¶
  • Insert the plastic opening tool into the indent and lift to remove the RAM cover.
Шаг 3  ¶
Use your fingernails to push the white and silver retaining clips away from each side of the RAM card. The RAM card should pop up at an angle.
Шаг 3  ¶
  • Use your fingernails to push the white and silver retaining clips away from each side of the RAM card.
  • The RAM card should pop up at an angle.
Шаг 4  ¶
Use your fingers to gently pull the RAM card away from the computer. Repeat step 9 to remove the other RAM card that may be installed.
Шаг 4  ¶
  • Use your fingers to gently pull the RAM card away from the computer.
  • Repeat step 9 to remove the other RAM card that may be installed.
