Помощь
Toshiba Satellite L305-S5946 Hard Drive Replacement
Буллеты!
Буллеты!
Использование примечания и разного цвета шрифта, в частности использование нумерации, поможет сделать это руководство более понятным!
Remove the hard drive from your Toshiba Satellite L305-S5946.
  • Автор: Alec
  • Времени уйдёт: 5 мин.
  • Сложность: Просто
Use this guide to replace or upgrade the hard drive in your Toshiba Satellite L305-S5946. If your hard drive is faulty or you want more storage, you should replace the hard drive.
Разделы
Инструменты
Шаг 1 Hard Drive  ¶
Use a Phillips #1 screwdriver to loosen the two screws on the bottom left-hand side of the hard drive cover.
Шаг 1 Hard Drive  ¶
  • Use a Phillips #1 screwdriver to loosen the two screws on the bottom left-hand side of the hard drive cover.
  • Turn each screw until you hear a click.
  • These are captive panel screws and remain with the cover.
Шаг 2  ¶
Lift the hard drive cover using a non-marring plastic opening tool. This will expose the hard drive.
Шаг 2  ¶
  • Lift the hard drive cover using a non-marring plastic opening tool.
  • This will expose the hard drive.
Шаг 3  ¶
Slide the hard drive to the left using your fingers. Insert a plastic opening tool under the right side of the hard drive. Carefully lift and remove the hard drive.
Шаг 3  ¶
  • Slide the hard drive to the left using your fingers.
  • Insert a plastic opening tool under the right side of the hard drive.
  • Carefully lift and remove the hard drive.
