Помощь
iMac Intel 27" EMC 2546 Display Replacement
Replace the display or remove it to access internal components.
Removing the display on the Late 2012 iMac requires cutting adhesive with a specialized iMac opening tool. After you've completed your repair, you'll need to follow our Adhesive Strip Guide to scrape off the old adhesive and replace it with new double-stick adhesive strips.
Шаг 1 Display  ¶
Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case. The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage. The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage.
Шаг 1 Display  ¶
  • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
  • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage.
Шаг 2  ¶
Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center. Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle. Run the tool up along the left side of the display.
Шаг 2  ¶
  • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
  • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
  • Run the tool up along the left side of the display.
Шаг 3  ¶
Continue wheeling the tool up around the top left corner. Continue wheeling the tool up around the top left corner. Continue wheeling the tool up around the top left corner.
Шаг 3  ¶
  • Continue wheeling the tool up around the top left corner.
Шаг 4  ¶
Cut the adhesive along the top left of the display. Cut the adhesive along the top left of the display.
Шаг 4  ¶
  • Cut the adhesive along the top left of the display.
Шаг 5  ¶
Continue along the top of the display. You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
Шаг 5  ¶
  • Continue along the top of the display.
  • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
Шаг 6  ¶
Push the tool around the top right corner of the display. Push the tool around the top right corner of the display. Push the tool around the top right corner of the display.
Шаг 6  ¶
  • Push the tool around the top right corner of the display.
Шаг 7  ¶
Wheel the tool down along the right side of the display. Wheel the tool down along the right side of the display.
Шаг 7  ¶
  • Wheel the tool down along the right side of the display.
Шаг 8  ¶
Finish pushing the opening tool to the bottom of the right side of the display. At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
Шаг 8  ¶
  • Finish pushing the opening tool to the bottom of the right side of the display.
  • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
Шаг 9  ¶
While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive. Set the iMac face-up on a table. Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
Шаг 9  ¶
  • While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
  • Set the iMac face-up on a table.
  • Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
  • Be careful not to insert it more than 3/8" (9.5 mm), or you may damage internal components.
Шаг 10  ¶
Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner. Using too much force will crack the glass. Work carefully, and don't try to create a gap any larger than about 1/4" (6 mm).
Шаг 10  ¶
  • Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner.
  • Using too much force will crack the glass. Work carefully, and don't try to create a gap any larger than about 1/4" (6 mm).
Шаг 11  ¶
Be sure to stop cutting before the iSight camera in this step, or you may damage it. Slide the card toward the center of the display, to cut any remaining adhesive. Slide the card toward the center of the display, to cut any remaining adhesive.
Шаг 11  ¶
  • Be sure to stop cutting before the iSight camera in this step, or you may damage it.
  • Slide the card toward the center of the display, to cut any remaining adhesive.
Шаг 12  ¶
Put the card into the corner again and let it stay there to keep the adhesive from resettling. Put the card into the corner again and let it stay there to keep the adhesive from resettling.
Шаг 12  ¶
  • Put the card into the corner again and let it stay there to keep the adhesive from resettling.
Шаг 13  ¶
Insert a second card into the gap between the display and frame in the top left corner. Insert a second card into the gap between the display and frame in the top left corner. Insert a second card into the gap between the display and frame in the top left corner.
Шаг 13  ¶
  • Insert a second card into the gap between the display and frame in the top left corner.
Шаг 14  ¶
Gently twist the card, slightly increasing the space between the display and frame. As with the other side, move slowly to allow the adhesive to break, and be careful not to over-stress the display glass.
Шаг 14  ¶
  • Gently twist the card, slightly increasing the space between the display and frame.
  • As with the other side, move slowly to allow the adhesive to break, and be careful not to over-stress the display glass.
Шаг 15  ¶
Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera.
Шаг 15  ¶
  • Slide the plastic card toward the center, again stopping just before the iSight camera.
Шаг 16  ¶
Insert the card back into the top left corner. Insert the card back into the top left corner.
Шаг 16  ¶
  • Insert the card back into the top left corner.
Шаг 17  ¶
Only lift the display a few inches—it is still attached to the iMac by data and power cables. With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case. If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
Шаг 17  ¶
  • Only lift the display a few inches—it is still attached to the iMac by data and power cables.
  • With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
  • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
  • Begin to lift the top of the display up from the frame.
Шаг 18  ¶
While holding the display up with one hand, use the other to unplug the display power cable. Lift the display up enough to have easy access to the connections, but not so much that you stretch the cables and stress their connections (about 8").
Шаг 18  ¶
  • While holding the display up with one hand, use the other to unplug the display power cable.
  • Lift the display up enough to have easy access to the connections, but not so much that you stretch the cables and stress their connections (about 8").
Шаг 19  ¶
Flip up the metal retaining bracket on the display data cable. Disconnect the display data cable. This is a delicate connection that can easily be broken. Be sure to pull the display data cable connector straight out of its socket, toward the top of the iMac.
Шаг 19  ¶
  • Flip up the metal retaining bracket on the display data cable.
  • Disconnect the display data cable.
  • This is a delicate connection that can easily be broken. Be sure to pull the display data cable connector straight out of its socket, toward the top of the iMac.
Шаг 20  ¶
Lift the display up to a near-vertical position. At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
Шаг 20  ¶
  • Lift the display up to a near-vertical position.
  • At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  • Remove as much of the adhesive as possible by grabbing it at the outer edges, and then pulling or rolling it towards the middle.
Шаг 21  ¶
If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip. Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red). Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
Шаг 21  ¶
  • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
  • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
Шаг 22  ¶
Be very careful handling the display—it's big, heavy, and made of glass. The display has fragile edges. Avoid lifting the display by the corners. Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface. It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
Шаг 22  ¶
  • Be very careful handling the display—it's big, heavy, and made of glass. The display has fragile edges. Avoid lifting the display by the corners.
  • Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
  • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
  • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide when your repair is complete to replace the adhesive strips that secure the display to the rear enclosure.
Шаг 23  ¶
If you are replacing the display panel, you may need to transfer additional components from the old panel to the new one. Compare the back of the old display with the replacement display. Note all cables, sensors, and foam cushioning that are missing from the new display.
Шаг 23  ¶
  • If you are replacing the display panel, you may need to transfer additional components from the old panel to the new one. Compare the back of the old display with the replacement display. Note all cables, sensors, and foam cushioning that are missing from the new display.
  • If there is a wire or cable underneath adhesive tape, always pull the tape off first.
  • If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull directly on the delicate connectors.
  • Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
Шаг 24  ¶
With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
Шаг 24  ¶
  • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
