Помощь
Fitbit Flex Teardown
Разбираем
Разбираем
Разбирая устройство, мы даём возможность изучить его изнутри. Статьи из серии «Разбираем» не стоит использовать как руководства по вскрытию девайса.
Предлагаемое руководство
Эта инструкция была специально выделена сотрудниками iFixit.
Here at iFixit, we promote only the healthiest of lifestyles. We eat our vegetables at least once per week, and we never eat pizza two days in a row (unless it's leftovers, of course). One might go so far as to call us health freaks. We would not argue.
But we are iFixit, so of course we're sacrificing our fitness ambitions for science. We ripped into Fitbit's newest pedometer/heart rate monitor/sleep tracker wristband. What kind of a diet helped this thing fit into its tiny jacket? We're about to find out.
Check out Instagram if you're interested in getting a behind-the-scenes look at iFixit. Food, gnomes, and fancy filters not your thing? Get a healthy dose of fighting eWaste on Twitter and Facebook.
Инструменты (продолжение)
Шаг 1 Fitbit Flex Teardown  ¶
So many goodies in one package! The Fitbit Flex comes with the following: Two adjustable wristbands: one large, one small Wireless sync dongle
  • So many goodies in one package! The Fitbit Flex comes with the following:
  • Two adjustable wristbands: one large, one small
  • Wireless sync dongle
  • Charging cable
  • The Flex tracker sports some cool tech specs, too.
  • Bluetooth 4.0 syncing
  • Memory to store 30 days of data
  • 5-day battery life
Шаг 2  ¶
With less effort than peeling an orange, we peel the Fitbit Flex tracker out of the flexible wrist strap. Although it seems like a small consideration, we appreciate how easy it is to separate the electronics from the wrist strap—the component most likely to wear out. Although it seems like a small consideration, we appreciate how easy it is to separate the electronics from the wrist strap—the component most likely to wear out.
Шаг 2  ¶
  • With less effort than peeling an orange, we peel the Fitbit Flex tracker out of the flexible wrist strap.
  • Although it seems like a small consideration, we appreciate how easy it is to separate the electronics from the wrist strap—the component most likely to wear out.
Шаг 3  ¶
Normally we would compare the device to other similar devices. Unfortunately, we don't really have much to compare the Flex to. How about a half dollar? The Flex may be slightly larger than a half dollar (though smaller than half a dollar bill), but it will cost you 200 of them.
Шаг 3  ¶
  • Normally we would compare the device to other similar devices. Unfortunately, we don't really have much to compare the Flex to. How about a half dollar?
  • The Flex may be slightly larger than a half dollar (though smaller than half a dollar bill), but it will cost you 200 of them.
  • If anyone pays for a Fitbit Flex with half dollars, we would love to hear about it.
  • The back of the Flex reveals the model number, FB401, and provides a nice insertion arrow. It's not quite disassembly information, but it's something, right?
Шаг 4  ¶
The first things we notice on the Flex are the waterproof contacts. This is good news for those who might be sweating while wearing, or tearing down, the Flex. For the record, the Flex claims to be water-tight up to 10 meters, or 264 simultaneous Gatorade showers. This tiny gizmo fits snugly in its USB charger when its lithium-polymer battery needs juice.
Шаг 4  ¶
  • The first things we notice on the Flex are the waterproof contacts. This is good news for those who might be sweating while wearing, or tearing down, the Flex.
  • For the record, the Flex claims to be water-tight up to 10 meters, or 264 simultaneous Gatorade showers.
  • This tiny gizmo fits snugly in its USB charger when its lithium-polymer battery needs juice.
  • Not to worry, it won't take the place of your smartphone on the charger each night—this little gadget has a reported battery life of 5 days.
Шаг 5  ¶
With no visible point of entry, we figure the  path to victory can be carved with judicious application of sharp tools. Around here, we're big fans of Dozuki. We're also big fans of dozukis. When saw comes to gadget, you know it's a teardown.
Шаг 5  ¶
  • With no visible point of entry, we figure the path to victory can be carved with judicious application of sharp tools.
  • Around here, we're big fans of Dozuki. We're also big fans of dozukis. When saw comes to gadget, you know it's a teardown.
  • Remember that teardowns are for fun and should not be followed as disassembly instructions. Please do not cut into your device with a dozuki.
Шаг 6  ¶
Our first extraction: the light guides for the LEDs that pass for a display on this slim, dare we say emaciated, unit. Next out is the Bluetooth antenna, used for communicating with devices and the accompanying dongle. Oops! We appear to have a tiny hitchhiker; that's a piece of the motherboard hanging on to the antenna.
Шаг 6  ¶
  • Our first extraction: the light guides for the LEDs that pass for a display on this slim, dare we say emaciated, unit.
  • Next out is the Bluetooth antenna, used for communicating with devices and the accompanying dongle.
  • Oops! We appear to have a tiny hitchhiker; that's a piece of the motherboard hanging on to the antenna.
  • To those of you following along at home: you don't need to chop up your PCB.
  • P.S. Don't follow along at home.
Шаг 7  ¶
Pulling components out through the top of the Flex worked for a little while, but it's time to get to the good stuff. Using our handy rotary tool, we cut through the plastic casing of the Flex tracker.
Шаг 7  ¶
  • Pulling components out through the top of the Flex worked for a little while, but it's time to get to the good stuff.
  • Using our handy rotary tool, we cut through the plastic casing of the Flex tracker.
  • Well hello there, Rico Suave! Peeling back the Flex's stylish plastic jacket reveals the components we've been looking for.
  • Repairability update: This little guy is never, ever, ever going back together.
Шаг 8  ¶
The main board slides right away from the contact pins. Now we can get to the juicy bits. Small and encased in a thin sheet of metal tape, the battery is soldered to the motherboard. By this point, a replaceable battery is the least of our worries. We're getting some good vibrations from the prominent vibrator that functions as an alarm.
Шаг 8  ¶
  • The main board slides right away from the contact pins. Now we can get to the juicy bits.
  • Small and encased in a thin sheet of metal tape, the battery is soldered to the motherboard. By this point, a replaceable battery is the least of our worries.
  • We're getting some good vibrations from the prominent vibrator that functions as an alarm.
Шаг 9  ¶
Шаг 9  ¶
  • This is how your vibrator works in your Fitbit Flex.
Шаг 10  ¶
Stuck right on to the front of the board we find a near field communications (NFC) antenna. The NFC tag enables a tap launch of the Flex tracker's associated mobile app with "select NFC-enabled Android devices." "It's like magic."
Шаг 10  ¶
  • Stuck right on to the front of the board we find a near field communications (NFC) antenna.
  • The NFC tag enables a tap launch of the Flex tracker's associated mobile app with "select NFC-enabled Android devices."
  • "It's like magic."
  • This little guy looks like a likely candidate for the NFC controller.
Шаг 11  ¶
The motherboard flexes to show us what it's repping: STMicroelectronics 32L151C6 Ultra Low Power ARM Cortex M3 Microcontroller
Шаг 11  ¶
  • The motherboard flexes to show us what it's repping:
  • STMicroelectronics 32L151C6 Ultra Low Power ARM Cortex M3 Microcontroller
  • Nordic Semiconductor nRF8001 Bluetooth Low Energy Connectivity IC
  • Our best guess is that this is the accelerometer IC
  • Charger IC: TI BQ24040
Шаг 12  ¶
We just couldn't keep our scalpels to ourselves, so we ripped into the Flex's dongle as well. Plastic aside, we get to the goodies. We quickly free the dongle board from the metal casing of the USB plug.
Шаг 12  ¶
  • We just couldn't keep our scalpels to ourselves, so we ripped into the Flex's dongle as well.
  • Plastic aside, we get to the goodies.
  • We quickly free the dongle board from the metal casing of the USB plug.
Шаг 13  ¶
Enough loligagging, let's cut to the chase. This diminutive USB board houses all of the hardware needed to communicate with the Flex — and your computer: Texas Instruments CC2540F128 2.4 GHz Bluetooth Low Energy SoC
Шаг 13  ¶
  • Enough loligagging, let's cut to the chase. This diminutive USB board houses all of the hardware needed to communicate with the Flex — and your computer:
  • Texas Instruments CC2540F128 2.4 GHz Bluetooth Low Energy SoC
  • On the contact side:
  • BLE Antenna
  • USB connection contacts
Шаг 14  ¶
Fitbit Flex Repairability Score: 2 out of 10 (10 is easiest to repair) Solid waterproofing, no moving parts, and lightweight construction make the Flex a very durable device, with the potential to last a long time.
Шаг 14  ¶
  • Fitbit Flex Repairability Score: 2 out of 10 (10 is easiest to repair)
  • Solid waterproofing, no moving parts, and lightweight construction make the Flex a very durable device, with the potential to last a long time.
  • The wrist strap is similarly constructed and can be easily replaced.
  • It's impossible to open the device without destroying it or at least compromising the waterproofing, making internal repairs infeasible.
  • The Flex's inaccessible (and non-replaceable) battery limits the life of the device.
