Помощь
Démontage de super-vario 40 display braille
Инструкция участника сообщества
Мы благодарны участнику нашего сообщества за составление этой инструкции. Она не редактируется сотрудниками iFixit.
vous allez accomplir le démontage complet de super vario 40 Baum
  • Автор: Sisyphe
  • Времени уйдёт: 15 мин.
  • Сложность: Средняя
Use this guide to assist with general disassembly or troubleshooting of your braille display.
Инструменты
Шаг 1 Démontage de super-vario 40 display braille  ¶
Remove the four bottom screws with a Phillips #00 screwdriver. Remove the four bottom screws with a Phillips #00 screwdriver.
  • Remove the four bottom screws with a Phillips #00 screwdriver.
Шаг 2  ¶
Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset.
Шаг 2  ¶
  • Remove the plastic cover, paper and chipset.
Шаг 3  ¶
Remove the two screws with a Phillips #00 screwdriver on the logic board. take out the main circuit like show in the picture take out the main circuit like show in the picture
Шаг 3  ¶
  • Remove the two screws with a Phillips #00 screwdriver on the logic board.
  • take out the main circuit like show in the picture
Шаг 4  ¶
Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver.
Шаг 4  ¶
  • Remove the four screws with a Phillips #00 screwdriver.
Шаг 5  ¶
Remove the connector delicately. Remove the connector delicately. Remove the connector delicately.
Шаг 5  ¶
  • Remove the connector delicately.
Шаг 6  ¶
when you put it back together make sure mechanical cells are connected correctly when you put it back together make sure mechanical cells are connected correctly
Шаг 6  ¶
  • when you put it back together make sure mechanical cells are connected correctly
