Помощь
iBook G4 12" 800 MHz-1.2 GHz Modem Replacement
  • Автор: iRobot
  • Сложность: Сложно
56k internal modem, standard on all models.
Разделы
Файлы
Инструменты
Шаг 1 Modem  ¶
Due to variations between iBook G4 models, your modem may look slightly different from the picture. All of the following steps apply to either model.
Шаг 1 Modem  ¶
  • Due to variations between iBook G4 models, your modem may look slightly different from the picture. All of the following steps apply to either model.
  • Remove the two Phillips screws at the corners of the modem.
Шаг 2  ¶
Lift the modem and modem shield from the bottom.
Шаг 2  ¶
  • Lift the modem and modem shield from the bottom.
Шаг 3  ¶
Disconnect the RJ-11 cable from the top of the modem.
Шаг 3  ¶
  • Disconnect the RJ-11 cable from the top of the modem.
  • When replacing the modem, seat the shield first, and then connect the modem and press it firmly into the shield, making sure that it is connected to the logic board.
