Помощь
MacBook Pro 15" Unibody Mid 2009 Hard Drive Cable Replacement
The hard drive cable includes the IR sensor/sleep indicator.
Разделы
Инструменты
Шаг 1 Hard Drive Cable  ¶
Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
  • Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
  • Two 1.5 mm Phillips screws.
  • Two 4 mm Phillips screws.
Шаг 2  ¶
Slide the hard drive and IR sensor bracket away from the edge of the upper case.
Шаг 2  ¶
  • Slide the hard drive and IR sensor bracket away from the edge of the upper case.
Шаг 3  ¶
Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
Шаг 3  ¶
  • Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
Шаг 4  ¶
Carefully peel the hard drive and IR sensor cable off the right speaker body/upper case and remove them from your computer. Carefully peel the hard drive and IR sensor cable off the right speaker body/upper case and remove them from your computer.
Шаг 4  ¶
  • Carefully peel the hard drive and IR sensor cable off the right speaker body/upper case and remove them from your computer.
Шаг 5  ¶
Your replacement part may or may not come with the front (sensor) bracket. If it does not, you'll need to transfer it to your new cable. Use the tip of a spudger to flip the ZIF connector on the hard drive cable. Gently pull the sensor bracket cable out of the ZIF connector.
Шаг 5  ¶
  • Your replacement part may or may not come with the front (sensor) bracket. If it does not, you'll need to transfer it to your new cable.
  • Use the tip of a spudger to flip the ZIF connector on the hard drive cable.
  • Gently pull the sensor bracket cable out of the ZIF connector.
  • Use the flat end of a spudger to pry the hard drive cable up off the sensor bracket.
  • Remove the adhesive backing from your new hard drive cable, stick it onto the sensor bracket, and connect the sensor bracket cable.
