Помощь
Tungsten E Disassembly
Ненаглядные фото
Ненаглядные фото
Будьте героем экшена! Изображения в этой инструкции должны более наглядно демонстрировать, как нужно выполнять то или иное действие.
A complete disassembly of a Palm Tungsten E.
  • Автор: Kevin Hom
  • Времени уйдёт: 15 мин.
  • Сложность: Средняя
This is a step by step guide to completely disassemble a Palm Tungsten E.
Шаг 1 Tungsten E Disassembly  ¶
Remove the stylus and SD card. Using a T5 torx screwdriver, remove all 4 back panel screws.
  • Remove the stylus and SD card.
  • Using a T5 torx screwdriver, remove all 4 back panel screws.
  • The screws are small and can be lost easily. Be sure to place them in a secure area.
Шаг 2  ¶
Insert a plastic opening tool under the USB and power input slots. Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely. Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
Шаг 2  ¶
  • Insert a plastic opening tool under the USB and power input slots.
  • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
Шаг 3  ¶
Your device may not have a screen protector. If not, you can move on to step four. Remove the screen protector by lifting the hinge out of the plastic housing.
Шаг 3  ¶
  • Your device may not have a screen protector. If not, you can move on to step four.
  • Remove the screen protector by lifting the hinge out of the plastic housing.
  • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
Шаг 4  ¶
Carefully remove motherboard from the standoffs without damaging the LCD flex connector. Using a spudger, unlock both sides of the flex connector block by pushing down.
Шаг 4  ¶
  • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
  • Using a spudger, unlock both sides of the flex connector block by pushing down.
  • Remove motherboard completely.
  • Metal washers may pop out of the device during this step
Шаг 5  ¶
Remove buttons using fingers. Gently flex frame to release screen from plastic frame. Lift out screen.
Шаг 5  ¶
  • Remove buttons using fingers.
  • Gently flex frame to release screen from plastic frame.
  • Lift out screen.
Шаг 6  ¶
Congratulations! You have successfully taken apart a Palm Tungsten E.
Шаг 6  ¶
  • Congratulations! You have successfully taken apart a Palm Tungsten E.
