Помощь
Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement
Replace the LCD in a Welch Allyn 6000 series Connex vital signs monitor.
Use this guide to replace a broken or non-functioning LCD in your Welch Allyn 6000 series Connex vital signs monitor.
PLEASE NOTE: This repair guide was developed by the iFixit team based on Welch Allyn's own service manual. Neither iFixit nor this repair guide is endorsed by or affiliated with Welch Allyn.
Разделы
Шаг 1 LCD  ¶
Remove the two Phillips #2 side housing screws from the bottom housing. There are holes above the screws into which you may insert a standard size screwdriver to unscrew them.
Шаг 1 LCD  ¶
  • Remove the two Phillips #2 side housing screws from the bottom housing.
  • There are holes above the screws into which you may insert a standard size screwdriver to unscrew them.
Шаг 2  ¶
Remove the single Phillips #2 screw from the bottom housing near the speaker grille.
Шаг 2  ¶
  • Remove the single Phillips #2 screw from the bottom housing near the speaker grille.
Шаг 3  ¶
Remove the bottom housing. Remove the bottom housing.
Шаг 3  ¶
  • Remove the bottom housing.
Шаг 4  ¶
Remove the ethernet cable, or simply tuck it out of the way. Remove the ethernet cable, or simply tuck it out of the way.
Шаг 4  ¶
  • Remove the ethernet cable, or simply tuck it out of the way.
Шаг 5  ¶
Remove the light-bar cable from the LCD bracket and move it out of the way. During reassembly, refer to the third image for tape and cable replacement. During reassembly, refer to the third image for tape and cable replacement.
Шаг 5  ¶
  • Remove the light-bar cable from the LCD bracket and move it out of the way.
  • During reassembly, refer to the third image for tape and cable replacement.
Шаг 6  ¶
Remove any tape from the LCD cable connector. For reassembly, refer to the third image for tape and cable replacement. For reassembly, refer to the third image for tape and cable replacement.
Шаг 6  ¶
  • Remove any tape from the LCD cable connector.
  • For reassembly, refer to the third image for tape and cable replacement.
Шаг 7  ¶
Pull the LCD cable connector, firmly and evenly, straight out of its socket. Pull the LCD cable connector, firmly and evenly, straight out of its socket.
Шаг 7  ¶
  • Pull the LCD cable connector, firmly and evenly, straight out of its socket.
Шаг 8  ¶
Remove the four Phillips #2 screws from the LCD bracket.
Шаг 8  ¶
  • Remove the four Phillips #2 screws from the LCD bracket.
Шаг 9  ¶
Remove the LCD bracket. Remove the LCD bracket.
Шаг 9  ¶
  • Remove the LCD bracket.
Шаг 10  ¶
Use the flat end of a spudger to lift the LCD out of the rubber gasket frame. Use the flat end of a spudger to lift the LCD out of the rubber gasket frame.
Шаг 10  ¶
  • Use the flat end of a spudger to lift the LCD out of the rubber gasket frame.
Шаг 11  ¶
Remove the LCD from the front housing. Remove the LCD from the front housing.
Шаг 11  ¶
  • Remove the LCD from the front housing.
