Помощь
iBook G4 14" 933 MHz-1.33 GHz Lower Case Replacement
  • Автор: iRobot
  • Сложность: Средняя
Replacing the plastic bottom case.
Разделы
Файлы
Инструменты
Инструменты (продолжение)
Связанные запчасти
Шаг 1 Lower Case  ¶
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Шаг 1 Lower Case  ¶
  • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Шаг 2  ¶
Remove the three newly-revealed Phillips screws.
Шаг 2  ¶
  • Remove the three newly-revealed Phillips screws.
Шаг 3  ¶
Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
Шаг 3  ¶
  • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
Шаг 4  ¶
Remove the three hex screws using a T8 Torx screwdriver (or Allen screws using an Allen key if these are used).
Шаг 4  ¶
  • Remove the three hex screws using a T8 Torx screwdriver (or Allen screws using an Allen key if these are used).
  • The shorter screw is in the center of the computer.
Шаг 5  ¶
Remove the two Phillips screws on either side of the battery contacts.
Шаг 5  ¶
  • Remove the two Phillips screws on either side of the battery contacts.
Шаг 6  ¶
Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
Шаг 6  ¶
  • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
  • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
Шаг 7  ¶
There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
Шаг 7  ¶
  • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
  • Be careful not to break this clip!
Шаг 8  ¶
Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
Шаг 8  ¶
  • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
Шаг 9  ¶
Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
Шаг 9  ¶
  • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
Шаг 10  ¶
There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
Шаг 10  ¶
  • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
Шаг 11  ¶
Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
Шаг 11  ¶
  • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
Шаг 12  ¶
Remove the small greasy springs with white plastic caps from either side of the battery contacts.
Шаг 12  ¶
  • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
