Помощь
Installing Sewing Machine Bobbin
Worn Wear
Worn Wear
Patagonia и iFixit отмечают истории, которые у нас есть, объединившись, чтобы предоставить руководство по ремонту самой популярной одежды Patagonia.
Follow these steps to install sewing machine bobbin.
  • Автор: Brittany McCrigler
  • Времени уйдёт: 5 мин.
  • Сложность: Просто
A bobbin is a small spool of thread that feeds the thread for the backside of the stitch. No sewing machine can sew without one. An incorrectly set up bobbin will create tangles in the thread. Bobbin setups vary from machine to machine. This guide shows the process for a Bernina 830, but the process will be similar for most sewing machines, except for those with drop-in bobbins. Refer to your sewing machine’s owner’s manual for specific directions on how to install a bobbin in your machine.
Инструменты
Шаг 1 Bobbin  ¶
Use your finger to open the bobbin door below the presser foot. Use your finger to open the bobbin door below the presser foot.
Шаг 1 Bobbin  ¶
  • Use your finger to open the bobbin door below the presser foot.
Шаг 2  ¶
Align the hole in the bobbin spindle over the peg in the bobbin case. Slide the bobbin into the bobbin case, leaving a bit of thread outside the case.
Шаг 2  ¶
  • Align the hole in the bobbin spindle over the peg in the bobbin case.
  • Slide the bobbin into the bobbin case, leaving a bit of thread outside the case.
  • Take the loose thread end and slide it through the slit on the side of the bobbin case.
Шаг 3  ¶
Slide the thread from the slit straight up along the groove and into the open hole on  the bobbin case's side. Slide the thread from the slit straight up along the groove and into the open hole on  the bobbin case's side.
Шаг 3  ¶
  • Slide the thread from the slit straight up along the groove and into the open hole on the bobbin case's side.
Шаг 4  ¶
Keeping the bobbin in place, turn the bobbin case so that the back is facing you. Use your fingernail to lift the lever on the back of the bobbin case. Hold the lever open.
Шаг 4  ¶
  • Keeping the bobbin in place, turn the bobbin case so that the back is facing you.
  • Use your fingernail to lift the lever on the back of the bobbin case. Hold the lever open.
Шаг 5  ¶
Holding the bobbin case lever open, insert the bobbin case into the cavity under the presser foot. Align the metal arm on the bobbin case so that it sits in the slot in the machine.
Шаг 5  ¶
  • Holding the bobbin case lever open, insert the bobbin case into the cavity under the presser foot.
  • Align the metal arm on the bobbin case so that it sits in the slot in the machine.
  • Release the bobbin case.
Шаг 6  ¶
Close the door on the compartment below the presser foot. Close the door on the compartment below the presser foot.
Шаг 6  ¶
  • Close the door on the compartment below the presser foot.
