Помощь
Solio CLASSIC2 Removing the Circuit Board
This guide will help you disconnect the circuit board from the device. This is a prerequisite guide.
  • Автор: Eric Padilla
  • Времени уйдёт: 15 - 20 мин.
  • Сложность: Средняя
Removing the circuit board will allow you to more easily solder on the circuit board.
Разделы
Инструменты
Шаг 1 Circuit Board  ¶
Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
  • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
Шаг 2  ¶
Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
Шаг 2  ¶
  • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
  • Gently lift the circuit board out of the device using tweezers.
