Помощь
PowerBook G4 Aluminum 12" 867 MHz Display Replacement
  • Автор: iRobot
  • Сложность: Сложно
Change out the entire display assembly, including the inverter, Airport antenna, hinges and metal casing.
Разделы
Шаг 1 Display  ¶
Deroute the Airport Extreme antenna from the card slot and lower case, removing tape as necessary.
Шаг 1 Display  ¶
  • Deroute the Airport Extreme antenna from the card slot and lower case, removing tape as necessary.
Шаг 2  ¶
Place a cloth between the screen and the bottom case.
Шаг 2  ¶
  • Place a cloth between the screen and the bottom case.
  • Close the bottom case and turn the laptop over.
  • Remove the two Phillips screws from the bottom case.
Шаг 3  ¶
Remove the two Phillips screws from either side of the display hinge.
Шаг 3  ¶
  • Remove the two Phillips screws from either side of the display hinge.
Шаг 4  ¶
Grasp the lower case and push down on the hinge side while rotating the other end of the case toward you until it pops free, then remove it entirely (leaving the display).
Шаг 4  ¶
  • Grasp the lower case and push down on the hinge side while rotating the other end of the case toward you until it pops free, then remove it entirely (leaving the display).
  • You have effectively removed the computer from the display.
