Помощь
Canon EOS 300 Bottom Panel Replacement
Use this guide to remove the bottom panel of the Canon EOS 300.
  • Автор: Tammy Kong
  • Времени уйдёт: 10 мин.
  • Сложность: Просто
The bottom panel can be easily removed, and allows access for replacement on other parts of the camera.
Разделы
Инструменты
Шаг 1 Bottom Panel  ¶
Remove three black 7.3mm Phillips #1 screws located on the corners of the camera. Remove five black 4.8mm Phillips #1 screws.
  • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
  • Remove five black 4.8mm Phillips #1 screws.
Шаг 2  ¶
Simply remove the bottom panel by prying it off with your finger. When removing the panel, be sure the bottom of the camera is facing upright.  There are loose gears that may fall out. Be wary of a loose piece of foam attached to the bottom panel.
Шаг 2  ¶
  • Simply remove the bottom panel by prying it off with your finger.
  • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
  • Be wary of a loose piece of foam attached to the bottom panel.
