Помощь
Samsung SPH-A640 Screen Replacement
Нужны более качественные фото
Лучшие фотографии будут усовершенствовать руководство. Помоги нам, редактирую старые или сделай и загрузи новые!
Пропущенные шаги
Пропущенные шаги
Ой! В этом руководстве в настоящее время отсутствуют некоторые важные шаги.
Replace the screen of your Samsung SPH-A640.
This guide will provide the steps necessary for replacing the screen in the Samsung SPH-A640 cellular telephone.
Разделы
Инструменты
Инструменты (продолжение)
Шаг 1 Screen  ¶
Using a #00 Phillips screwdriver, remove four screws from the bottom half of the phone in the battery compartment. The screws are in each corner. Place screws off to the side.
Шаг 1 Screen  ¶
  • Using a #00 Phillips screwdriver, remove four screws from the bottom half of the phone in the battery compartment. The screws are in each corner. Place screws off to the side.
Шаг 2  ¶
Using a plastic opening tool, pry off back cover starting at the bottom corners and moving around the perimeter towards the hinge.
Шаг 2  ¶
  • Using a plastic opening tool, pry off back cover starting at the bottom corners and moving around the perimeter towards the hinge.
  • Disengaging the clips near the hinge may require some force.
Шаг 3  ¶
Using tweezers, carefully remove the buttons from both sides while removing the back cover.
Шаг 3  ¶
  • Using tweezers, carefully remove the buttons from both sides while removing the back cover.
  • Note the positions of the buttons. They must be returned to the same positions.
Шаг 4  ¶
Once the back is removed, use a plastic opening tool to disconnect the electrical connector near the hinge.
Шаг 4  ¶
  • Once the back is removed, use a plastic opening tool to disconnect the electrical connector near the hinge.
Шаг 5  ¶
Peel off the screw covers and remove two exposed Phillips head screws with a small Phillips head screwdriver.
Шаг 5  ¶
  • Peel off the screw covers and remove two exposed Phillips head screws with a small Phillips head screwdriver.
Шаг 6  ¶
Remove the front cover of the phone using a plastic opening tool.
Шаг 6  ¶
  • Remove the front cover of the phone using a plastic opening tool.
  • Slide a plastic opening tool along the seam from the hinge around the perimeter.
Шаг 7  ¶
Using a plastic opening tool, disconnect the electrical connector. The electrical connector is located near the hinge and is revealed when the front cover is removed.
Шаг 7  ¶
  • Using a plastic opening tool, disconnect the electrical connector. The electrical connector is located near the hinge and is revealed when the front cover is removed.
Шаг 8  ¶
Using a plastic opening tool, pry the speakers from the case. These are located at the top of the back of the phone. Using a plastic opening tool, pry the speakers from the case. These are located at the top of the back of the phone.
Шаг 8  ¶
  • Using a plastic opening tool, pry the speakers from the case. These are located at the top of the back of the phone.
Шаг 9  ¶
Using a plastic opening tool, lift the screen assembly from the case. Using a plastic opening tool, lift the screen assembly from the case.
Шаг 9  ¶
  • Using a plastic opening tool, lift the screen assembly from the case.
Шаг 10  ¶
Нет изображения
Шаг 10  ¶
  • To the best of our knowledge, remove the hinge to free the ribbon cable from the case and remove the screen assembly.
