Помощь
HP Deskjet D1660 Rollers Replacement
Replace the rollers so that the paper will smoothly run through the printer.
  • Автор: Justin Taiki Fukada
  • Времени уйдёт: 20 - 25 мин.
  • Сложность: Средняя
This guide will replace the small rollers located under the ink carriage. Rollers enable the papers to run smoothly through the printer and cleanly print out material.
Разделы
Инструменты
Шаг 1 Rollers  ¶
Remove the five 13.0 mm Torx #10 screws found on top of the frame. Remove the four 9.0 mm Torx #10 smaller screws.
Шаг 1 Rollers  ¶
  • Remove the five 13.0 mm Torx #10 screws found on top of the frame.
  • Remove the four 9.0 mm Torx #10 smaller screws.
Шаг 2  ¶
Lift the cover up using both of your hands. Lift it carefully as a strip and motor will be connected to the bottom part of the printer.
Шаг 2  ¶
  • Lift the cover up using both of your hands.
  • Lift it carefully as a strip and motor will be connected to the bottom part of the printer.
Шаг 3  ¶
Locate the rollers, which will be on the bottom of the metal frame that holds the carriage. Grab the rollers and remove them by pulling them to one side and lifting them up.
Шаг 3  ¶
  • Locate the rollers, which will be on the bottom of the metal frame that holds the carriage.
  • Grab the rollers and remove them by pulling them to one side and lifting them up.
  • Do the same for the other three.
