Помощь
Disassembling Xbox 360 E Top Body
Remove the top body of your Xbox 360 E.
  • Автор: Sarah
  • Времени уйдёт: 5 мин.
  • Сложность: Просто
You will need to remove the top body of your Xbox 360 E in order to get inside your Xbox and replace other parts, such as the CD drive or motherboard.
Разделы
Инструменты
Шаг 1 Top Body  ¶
Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver. Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
Шаг 1 Top Body  ¶
  • Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver.
  • Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
