Помощь
InFocus LP540 Projector Lamp Replacement
Неправильные инструменты
Помогите улучшить эту инструкцию — пусть в кадре и в тексте будут правильные инструменты.
Лучше введение
Лучше введение
Улучши это руководство, заполнив или отредактировав его.
This guide will assist with replacing a non-functioning projector lamp, which is responsible for providing the light necessary for projection.
  • Автор: Jorge L Navarro
  • Времени уйдёт: 5 - 10 мин.
  • Сложность: Просто
Шаг 1 Lamp  ¶
Place the projector on its back with the control buttons facing down. Remove the black  7mm screw on the external case with a Phillips 2 screwdriver.
Шаг 1 Lamp  ¶
  • Place the projector on its back with the control buttons facing down.
  • Remove the black 7mm screw on the external case with a Phillips 2 screwdriver.
Шаг 2  ¶
Use the plastic flat-head to remove the lamp lid.
Шаг 2  ¶
  • Use the plastic flat-head to remove the lamp lid.
Шаг 3  ¶
Remove the 7mm screw near the bottom center with a Philips 2 screwdriver head. Loosen but do not remove the 7mm screw near the upper right corner with the Phillips 2 screwdriver head.
Шаг 3  ¶
  • Remove the 7mm screw near the bottom center with a Philips 2 screwdriver head.
  • Loosen but do not remove the 7mm screw near the upper right corner with the Phillips 2 screwdriver head.
Шаг 4  ¶
Grab the silver handle. Unhook the handle so it can move freely. Pull the handle straight up until the lamp is completely removed from projector.
Шаг 4  ¶
  • Grab the silver handle.
  • Unhook the handle so it can move freely.
  • Pull the handle straight up until the lamp is completely removed from projector.
