Помощь
Anker 2.4G Wireless Mouse Sensor Replacement
Граммар-наци
Граммар-наци
Разбуди в себе учителя английского, помогая улучшить грамматику этого руководства!
Неправильные инструменты
Помогите улучшить эту инструкцию — пусть в кадре и в тексте будут правильные инструменты.
Лучше введение
Лучше введение
Улучши это руководство, заполнив или отредактировав его.
The sensor will be replaced so the mouse can operate normally.
  • Автор: Ryan
  • Времени уйдёт: 15 мин.
  • Сложность: Средняя
Инструменты
Связанные запчасти
Шаг 1 Sensor  ¶
Use the screwdriver to pry off the stickers marked in red to reveal the location of 4 screws.
Шаг 1 Sensor  ¶
  • Use the screwdriver to pry off the stickers marked in red to reveal the location of 4 screws.
Шаг 2  ¶
Remove the 4 screws marked in red.
Шаг 2  ¶
  • Remove the 4 screws marked in red.
Шаг 3  ¶
Use a flat head screw driver to pry apart the upper and lower housing of the mouse. Use a flat head screw driver to pry apart the upper and lower housing of the mouse.
Шаг 3  ¶
  • Use a flat head screw driver to pry apart the upper and lower housing of the mouse.
Шаг 4  ¶
Pull the wires from the white crimping headers to disconnect them, separating the top from bottom.
Шаг 4  ¶
  • Pull the wires from the white crimping headers to disconnect them, separating the top from bottom.
  • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
Шаг 5  ¶
Remove the scroll wheel from the mother board by pulling it to the left.
Шаг 5  ¶
  • Remove the scroll wheel from the mother board by pulling it to the left.
  • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
Шаг 6  ¶
Pull the mother board gently away from the plastic housing.
Шаг 6  ¶
  • Pull the mother board gently away from the plastic housing.
Шаг 7  ¶
The IC (Integrated Circuit) is highlighted in red, it is the mouse sensor. Desolder the 6 wires holding the IC in place to complete the sensor change.
Шаг 7  ¶
  • The IC (Integrated Circuit) is highlighted in red, it is the mouse sensor.
  • Desolder the 6 wires holding the IC in place to complete the sensor change.
  • Replace component with new component and resolder back in place.
