Помощь
HP Pavilion dv6-1245dx RAM Replacement
Проблема с примечаниями
Примечания в этом руководстве должны быть более качественными. Помогите нам исправить их или написать новые аннотации.
Пропущенные шаги
Пропущенные шаги
Ой! В этом руководстве в настоящее время отсутствуют некоторые важные шаги.
If you want to increase the memory in your computer, or an internal memory card breaks, you can replace it with this guide.
  • Автор: Jaime
  • Времени уйдёт: 5 - 10 мин.
  • Сложность: Просто
In this guide, you will learn how to replace your RAM.
Инструменты
Связанные запчасти
Шаг 1 RAM  ¶
Shut down the computer and unplug it from the outlet.
Шаг 1 RAM  ¶
  • Shut down the computer and unplug it from the outlet.
  • All screws removed in this guide will require a Phillips #00 screwdriver.
Шаг 2  ¶
Turn the computer upside down.
Шаг 2  ¶
  • Turn the computer upside down.
Шаг 3  ¶
Loosen the three screws from the memory module compartment cover
Шаг 3  ¶
  • Loosen the three screws from the memory module compartment cover
  • Screws will not come all the way out.
Шаг 4  ¶
Remove the memory module compartment cover.
Шаг 4  ¶
  • Remove the memory module compartment cover.
Шаг 5  ¶
Remove the first memory module by spreading apart the two silver retaining tabs, using your thumb and index finger. Pull and lift the green memory module upward at a 45-degree angle, and then pull the memory module out of the computer. If you are replacing both memory cards, repeat this step with the bottom memory card.
Шаг 5  ¶
  • Remove the first memory module by spreading apart the two silver retaining tabs, using your thumb and index finger.
  • Pull and lift the green memory module upward at a 45-degree angle, and then pull the memory module out of the computer.
  • If you are replacing both memory cards, repeat this step with the bottom memory card.
Шаг 6  ¶
To replace the memory card, insert the card at a 45-degree angle, then push into slot.
Шаг 6  ¶
  • To replace the memory card, insert the card at a 45-degree angle, then push into slot.
  • Push down gently so the silver retaining tabs click back into place.
  • If you are replacing both memory cards, replace the bottom card (closest to the system board) first.
