Помощь
Dell Latitude D620 Keyboard Replacement
  • Автор: Miguel Wong
  • Времени уйдёт: 5 мин.
  • Сложность: Просто
Guide to removing the keyboard from the D620.
Инструменты
Шаг 1 Keyboard  ¶
Power down the laptop and remove the battery.
Шаг 1 Keyboard  ¶
  • Power down the laptop and remove the battery.
  • Open the laptop cover all of the way.
Шаг 2  ¶
Locate the notch under the cover at the top of the keyboard Using the spudger as a lever, lift the plastic covering Carefully remove the rest of the covering from right to left
Шаг 2  ¶
  • Locate the notch under the cover at the top of the keyboard
  • Using the spudger as a lever, lift the plastic covering
  • Carefully remove the rest of the covering from right to left
Шаг 3  ¶
Unscrew the top portion of the keyboard using a #00 screwdriver
Шаг 3  ¶
  • Unscrew the top portion of the keyboard using a #00 screwdriver
Шаг 4  ¶
Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
Шаг 4  ¶
  • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
  • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
Шаг 5  ¶
Once keyboard is out of the case, lay it face-down on the track pad Once keyboard is out of the case, lay it face-down on the track pad
Шаг 5  ¶
  • Once keyboard is out of the case, lay it face-down on the track pad
Шаг 6  ¶
Using a small spudger, pull back on the black bar to release the blue lever Using a small spudger, pull back on the black bar to release the blue lever
Шаг 6  ¶
  • Using a small spudger, pull back on the black bar to release the blue lever
Шаг 7  ¶
Pull up on the metal bar connected to the socket to detach the ribbon cable
Шаг 7  ¶
  • Pull up on the metal bar connected to the socket to detach the ribbon cable
