Помощь
Uniden TCX905 Back Shell Replacement
This guide will show the user how to remove the back shell of the Uniden TCX905 to access the internal hardware.
  • Автор: Gary Pence
  • Времени уйдёт: 2 - 5 мин.
  • Сложность: Средняя
The TCX905 consists of a two part shell. The back shell is where the battery and back speaker are, the front shell includes the buttons and the screen.
Разделы
Инструменты
Шаг 1 Back Shell  ¶
Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone) Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
Шаг 1 Back Shell  ¶
  • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
Шаг 2  ¶
Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
Шаг 2  ¶
  • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
Шаг 3  ¶
Ensure that wired connection between circuit board and back shell is not strained Fold the back shell underneath the front shell and circuit board Fold the back shell underneath the front shell and circuit board
Шаг 3  ¶
  • Ensure that wired connection between circuit board and back shell is not strained
  • Fold the back shell underneath the front shell and circuit board
