Помощь
Toshiba Satellite L305-S5875 LCD Screen Replacement
Нужны более качественные фото
Лучшие фотографии будут усовершенствовать руководство. Помоги нам, редактирую старые или сделай и загрузи новые!
Проблема с примечаниями
Примечания в этом руководстве должны быть более качественными. Помогите нам исправить их или написать новые аннотации.
This guide will help show you how to replace a damaged or malfunctioning LCD screen for the Toshiba Satellite L305-S5875 model laptop.
  • Автор: Joshua Lessard
  • Времени уйдёт: 30 - 35 мин.
  • Сложность: Средняя
Welcome to the Toshiba Satellite L305-S5875 LCD Screen Replacement guide page. The ultimate goal of this page is to show you how to replace the 15.4" LCD screen on your Toshiba Satellite laptop. This guide will go step by step in explaining how to work your way to the screen, and then how to replace the screen once you're there. This guide uses both visual and written instructions to help you replace your old damaged screen with a brand new one.
Разделы
Инструменты
Шаг 1 LCD Screen  ¶
Open the laptop so that you can see the screen.
Шаг 1 LCD Screen  ¶
  • Open the laptop so that you can see the screen.
Шаг 2  ¶
Remove the four rubber inserts from the four corners of the screen. Once removed, unscrew and remove the four screws found beneath the four rubber inserts.
Шаг 2  ¶
  • Remove the four rubber inserts from the four corners of the screen.
  • Once removed, unscrew and remove the four screws found beneath the four rubber inserts.
Шаг 3  ¶
Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop. Gently pull the back panel approximately 1 inch away from the screen. Warning: Following step will detach screen from casing. Use caution.
Шаг 3  ¶
  • Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop.
  • Gently pull the back panel approximately 1 inch away from the screen.
  • Warning: Following step will detach screen from casing. Use caution.
  • Unscrew and remove the 4 screws on the left and right side of the screen; 8 screws in total.
Шаг 4  ¶
Lay screen down on keyboard. On the back of the screen, locate the ribbon cable that connects the screen to the computer. Remove the tape from the cable if it is present. Carefully remove the ribbon cable by pulling it out of it's socket.
Шаг 4  ¶
  • Lay screen down on keyboard.
  • On the back of the screen, locate the ribbon cable that connects the screen to the computer. Remove the tape from the cable if it is present.
  • Carefully remove the ribbon cable by pulling it out of it's socket.
Шаг 5  ¶
At the bottom of the screen, locate the pink and white wires. Unplug the connector from the circuit board by gently pulling it out. Unplug the connector from the circuit board by gently pulling it out.
Шаг 5  ¶
  • At the bottom of the screen, locate the pink and white wires.
  • Unplug the connector from the circuit board by gently pulling it out.
Шаг 6  ¶
Congratulations, you have just removed your screen!
Шаг 6  ¶
  • Congratulations, you have just removed your screen!
