Помощь
Acer Aspire 5253 Battery Replacement
Removal and Replacement of Battery Pack
  • Автор: Joseph Gagliano
  • Времени уйдёт: 30 секунд
  • Сложность: Очень просто
Batteries are used to power the laptop, if your laptop is experiencing one of these (troubleshooting) problems, follow this guide to replace the battery pack.
Always remove the battery before opening any part of the laptop, it could cause you to be shocked.
Шаг 1 Battery  ¶
Turn the laptop over.
Шаг 1 Battery  ¶
  • Turn the laptop over.
Шаг 2  ¶
"Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
Шаг 2  ¶
  • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
Шаг 3  ¶
Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
Шаг 3  ¶
  • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
Шаг 4  ¶
Now remove the battery by lifting it out of the laptop by the side closest to the switches.
Шаг 4  ¶
  • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
Шаг 5  ¶
You have successfully removed the battery. Congratulations!
Шаг 5  ¶
  • You have successfully removed the battery. Congratulations!
