Помощь
Toshiba Satellite A105-S4284 LCD Display Replacement
Unscrew the hinges, Remove the laptop lid. separate the lid from the main body of the laptop. seperate the LCD from the lid.
  • Автор: Josh
  • Времени уйдёт: 10 мин.
  • Сложность: Средняя
The display is incorporated into the Lid of the laptop and is susceptible to cracking from falls or pressure. Often this could result in the laptop being unusable. This guide will show you how to disconnect and remove the Lid from the main laptop body, separate the LCD from the lid.
Разделы
Инструменты
Шаг 1 LCD Display  ¶
Remove the black and white wires. they simply lift off the posts. Remove the cable attaching the LCD to the motherboard, on the left side of the laptop. Remove the cable attaching the LCD to the motherboard, on the left side of the laptop.
Шаг 1 LCD Display  ¶
  • Remove the black and white wires. they simply lift off the posts.
  • Remove the cable attaching the LCD to the motherboard, on the left side of the laptop.
Шаг 2  ¶
Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers. Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
Шаг 2  ¶
  • Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers.
  • Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
Шаг 3  ¶
Peel off the rubber circles from the  four corners. Remove the four 4.0mm phillips screws. Remove the four 4.0mm phillips screws.
Шаг 3  ¶
  • Peel off the rubber circles from the four corners.
  • Remove the four 4.0mm phillips screws.
Шаг 4  ¶
Using the plastic prying tools separate the plastic surrounding the screen Lift out the broken LCD to be replaced. Lift out the broken LCD to be replaced.
Шаг 4  ¶
  • Using the plastic prying tools separate the plastic surrounding the screen
  • Lift out the broken LCD to be replaced.
