Помощь
Speaker Unit Replacement
This guide will help you replace dead speakers on an iHome iP37.
  • Автор: Jerrell
  • Времени уйдёт: 15 - 20 мин.
  • Сложность: Сложно
This guide will walk you through the process of replacing dead speakers on the iHome iP37.
Разделы
Инструменты
Инструменты (продолжение)
Шаг 1 Speaker Unit  ¶
Remove these eight 9 mm screws using a Phillips #2 driver.
  • Remove these eight 9 mm screws using a Phillips #2 driver.
Шаг 2  ¶
Carefully lift the cover off. It may be a little sticky from glue.
Шаг 2  ¶
  • Carefully lift the cover off. It may be a little sticky from glue.
Шаг 3  ¶
Remove the four 6mm screws that hold the broken speaker in place. This step requires a Phillips #1 driver. If you are replacing both speakers, remove all 8 screws.
Шаг 3  ¶
  • Remove the four 6mm screws that hold the broken speaker in place. This step requires a Phillips #1 driver. If you are replacing both speakers, remove all 8 screws.
Шаг 4  ¶
Caution: the speaker is fitted quite snug. it may take a bit of effort to remove. However, be careful not to pull too hard as you may accidentally pull on the wires once the speaker unit is free.
Шаг 4  ¶
  • Caution: the speaker is fitted quite snug. it may take a bit of effort to remove. However, be careful not to pull too hard as you may accidentally pull on the wires once the speaker unit is free.
  • Hold the speaker by its cylindrical frame and cautiously lift it away from the rest of the device.
Шаг 5  ¶
De-solder the existing soldered connections and remove the speaker from the rest of the device.
Шаг 5  ¶
  • De-solder the existing soldered connections and remove the speaker from the rest of the device.
  • Insert and solder in a working speaker of the same model. Make sure the points where the wire ends connected are consistent with the old speakers.
  • Note: If you notice that a wire is disconnected, this may be the cause of your problems. Re-solder the connection to fix it.
  • You can refer to iFixit's guide or this informative video for more information on soldering.
