Помощь
Disassembling IBM ThinkPad 560z Upper Case
  • Автор: Derek Driscoll
  • Времени уйдёт: 10 - 15 мин.
  • Сложность: Средняя
How to open up the IBM ThinkPad 560z
Разделы
Инструменты
Инструменты (продолжение)
Шаг 1 Upper Case  ¶
Remove the 7 mm Phillips #0 screws.
Шаг 1 Upper Case  ¶
  • Remove the 7 mm Phillips #0 screws.
  • Remove the 10 mm Phillips #0 screws.
  • Remove the 14 mm Phillips #0 screw.
Шаг 2  ¶
Open the flap on the left hand side. Open the flap on the left hand side.
Шаг 2  ¶
  • Open the flap on the left hand side.
Шаг 3  ¶
Insert the plastic opening tools between the right and left sides of the latch. Pry the right side  of the latch, and then pry the left side to detach the laptop's cover.
Шаг 3  ¶
  • Insert the plastic opening tools between the right and left sides of the latch.
  • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
Шаг 4  ¶
Open the flap on the right side. Open the flap on the right side.
Шаг 4  ¶
  • Open the flap on the right side.
Шаг 5  ¶
Insert the plastic opening tools towards the right side of the latch.
Шаг 5  ¶
  • Insert the plastic opening tools towards the right side of the latch.
  • Gently pry the right side out to release the top cover.
Шаг 6  ¶
Lift the keyboard slowly. A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
Шаг 6  ¶
  • Lift the keyboard slowly.
  • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
Шаг 7  ¶
Use your fingers or a spudger to detach the connector.
Шаг 7  ¶
  • Use your fingers or a spudger to detach the connector.
Шаг 8  ¶
Carefully lift and remove the keyboard. Carefully lift and remove the keyboard.
Шаг 8  ¶
  • Carefully lift and remove the keyboard.
