Помощь
Sony Ericsson Z500a Screen Replacement
Шаги триммера
Шаги триммера
Это руководство имеет лишние шаги. Убери их с тем чтобы руководство стало более коротким!
Запутанный текст
Запутанный текст
Некоторые части этого руководства является запутанными, дублируются или не по теме. Отредактируй их!
  • Автор: Morgan
  • Времени уйдёт: 20 - 25 мин.
  • Сложность: Средняя
This guide will allow you to remove the inside screen in order to replace it.
Разделы
Инструменты
Шаг 1 Screen  ¶
Close the phone, flip it over, grab the remaining gray covering of the phone and pull it straight up to remove it. There is another piece below     this which will break if you don't pull straight up.
Шаг 1 Screen  ¶
  • Close the phone, flip it over, grab the remaining gray covering of the phone and pull it straight up to remove it.
  • There is another piece below this which will break if you don't pull straight up.
  • Once the cover is removed take off the black piece underneath.
Шаг 2  ¶
Remove the face of the phone by sliding down.
Шаг 2  ¶
  • Remove the face of the phone by sliding down.
Шаг 3  ¶
Unscrew the 4 screws connecting the screen to the base using a T6 Precision screwdriver.
Шаг 3  ¶
  • Unscrew the 4 screws connecting the screen to the base using a T6 Precision screwdriver.
Шаг 4  ¶
Use ipod opening tool to pry up the edge of the remaining silver hinge cover. Once it is loose you can pull it off the rest of the way.
Шаг 4  ¶
  • Use ipod opening tool to pry up the edge of the remaining silver hinge cover.
  • Once it is loose you can pull it off the rest of the way.
Шаг 5  ¶
To remove the plastic cover on the screen, run the ipod opening tool along the sides between the cover and the body of the phone (like you did for the keyboard)and gently pry upward until it is loose. Like the keyboard there is one clamp on each side.
Шаг 5  ¶
  • To remove the plastic cover on the screen, run the ipod opening tool along the sides between the cover and the body of the phone (like you did for the keyboard)and gently pry upward until it is loose.
  • Like the keyboard there is one clamp on each side.
  • Grab the cover at the bottom of the screen (near the hinge) and pull outward while leaving the top (near the speaker) connected.
  • Once the bottom is pulled out far enough the top will be able to disconnect as well.
Шаг 6  ¶
Remove the tape on the bottom of the screen so that the screen will be able to come out.
Шаг 6  ¶
  • Remove the tape on the bottom of the screen so that the screen will be able to come out.
  • There is a finger notch on the top of the screen, gently pull out halfway.
  • Caution: the back of the screen is connected to the base of the phone. So do not pull out or the connection will be broken.
Шаг 7  ¶
Use the iPod opening device to remove the ribbon wire where it connects to the screen.
Шаг 7  ¶
  • Use the iPod opening device to remove the ribbon wire where it connects to the screen.
