Помощь
Samsung Galaxy Note 3 Rear Case Replacement
Your rear case is damaged and not so pretty, this is how you can make it brand new again.
Here you can learn to remove the rear case of your phone.
Связанные запчасти
Шаг 1 Remove the rear case  ¶
Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
Шаг 2 Remove Case from the Base  ¶
Slide your fingernail or plastic opening tool along the edge of the rear case. Lift the case gently from the base.
  • Slide your fingernail or plastic opening tool along the edge of the rear case.
  • Lift the case gently from the base.
