Помощь
Samsung Galaxy Tab 3 8.0 Motherboard Replacement
Проблема с примечаниями
Примечания в этом руководстве должны быть более качественными. Помогите нам исправить их или написать новые аннотации.
When all else fails, it's often the motherboard's fault. This guide will show you how to replace it.
  • Автор: Kyle Ballard
  • Времени уйдёт: 15 - 30 мин.
  • Сложность: Средняя
This guide will take you through the step-by-step process of removing and replacing the motherboard of a Samsung Galaxy Tab 3 8.0.
Разделы
Инструменты
Инструменты (продолжение)
Связанные запчасти
Шаг 1 Disconnect All Relays  ¶
Using a plastic remover tool, carefully unseat each of the electric leads plugged into the board. Using a plastic remover tool, carefully unseat each of the electric leads plugged into the board.
  • Using a plastic remover tool, carefully unseat each of the electric leads plugged into the board.
Шаг 2 Unscrew Motherboard  ¶
Unscrew the 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery. Unscrew the 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery. Unscrew the 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery.
  • Unscrew the 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery.
Шаг 3 Remove the Motherboard  ¶
Carefully lift the board from the device. Carefully lift the board from the device.
  • Carefully lift the board from the device.
