Помощь
GravityLight Mounting Post Replacement and Spring Replacement
This guide will show how to replace the mounting post and spring in the Gravitylight.
  • Автор: Jamie Forslin
  • Времени уйдёт: 5 - 10 мин.
  • Сложность: Просто
To remove the mounting post, you must take out all internal parts in front of the mounting post. Push down on the spring that is holding the mounting post in place. When the spring is compressed, both the mounting post and the spring can be removed if you push them away from the outside casing.
Разделы
Инструменты
Шаг 1 Orienting the Middle Section  ¶
Place the middle section on a sturdy surface.
  • Place the middle section on a sturdy surface.
  • Move any wires in front of the mounting post.
Шаг 2 Removing the Mounting Post from the Middle Section.  ¶
Push down on the spring. The spring is very stiff. Compressing the spring requires a moderate amount of force.
  • Push down on the spring.
  • The spring is very stiff. Compressing the spring requires a moderate amount of force.
  • Push the spring and the mounting post away from the middle section and remove them from the pocket.
Шаг 3 Separate Mounting Post and Spring  ¶
Pull the mounting post out of the inside of the spring Pull the mounting post out of the inside of the spring
  • Pull the mounting post out of the inside of the spring
