Помощь
Huawei Ascend P6-U06 Back Panel Replacement
Learn how to replace the back panel on your Huawei Ascend P6-U06.
  • Автор: Alison Jones
  • Времени уйдёт: 3 - 5 мин.
  • Сложность: Просто
Follow this guide to replace the back panel on your Huawei Ascend P6-U06.
Шаг 1 Back Panel  ¶
Firmly push down on the black plastic covering at the bottom of the phone, and pull down. You may need a sharp thin object to get underneath the plastic.
Шаг 1 Back Panel  ¶
  • Firmly push down on the black plastic covering at the bottom of the phone, and pull down.
  • You may need a sharp thin object to get underneath the plastic.
Шаг 2  ¶
Rotate the phone 180 degrees so that the bottom of the phone is now facing up. Firmly push up on the back panel with your thumbs.
Шаг 2  ¶
  • Rotate the phone 180 degrees so that the bottom of the phone is now facing up.
  • Firmly push up on the back panel with your thumbs.
  • Lift up the back panel from the top right corner and gently pull it away from the phone.
