Помощь
Apple Time Capsule Model A1302 Power Supply Replacement
Инструкция участника сообщества
Мы благодарны участнику нашего сообщества за составление этой инструкции. Она не редактируется сотрудниками iFixit.
Removing your Time Capsule's dead power supply in order to install a fresh one.
  • Автор: rousp
  • Времени уйдёт: 5 - 10 мин.
  • Сложность: Средняя
You are now going to:
  1. Open the Time Capsule
  2. Disconnect and remove the Power Supply
  3. Installing a new power supply if your old one is broken. Or re-install your old power supply if you do this for fun.
Разделы
Инструменты
Шаг 1 Power Supply  ¶
Power supply shown in blue Start by removing the AC plug by lifting it straight up.
  • Power supply shown in blue
  • Start by removing the AC plug by lifting it straight up.
Шаг 2  ¶
Using a spudger, unplug the cable that supplies the motherboard with power. There's a clip to release the locking mechanism; make sure to press and release the clip before pulling up on the connector. Then, using the same spudger, unplug the HDD power cable. If you're not used to working with data plugs in tight spaces it could be a good idea to remove the HDD first. Consult the HDD removal guide for instructions.
Шаг 2  ¶
  • Using a spudger, unplug the cable that supplies the motherboard with power. There's a clip to release the locking mechanism; make sure to press and release the clip before pulling up on the connector.
  • Then, using the same spudger, unplug the HDD power cable.
  • If you're not used to working with data plugs in tight spaces it could be a good idea to remove the HDD first. Consult the HDD removal guide for instructions.
Шаг 3  ¶
Lift the power supply out of its mountings. The mounts can snag the motherboard somewhat. Just fiddle it a little and it will come loose.
Шаг 3  ¶
  • Lift the power supply out of its mountings.
  • The mounts can snag the motherboard somewhat. Just fiddle it a little and it will come loose.
