Помощь
Nintendo DSi XL Motherboard Replacement
Предлагаемое руководство
Эта инструкция была специально выделена сотрудниками iFixit.
Replacing the motherboard on the Nintendo DSi XL.
  • Автор: Brett Hartt
  • Сложность: Средняя
Drop your DSi XL into the pool? Use this guide to repair or replace your motherboard.
Разделы
Инструменты
Инструменты (продолжение)
Связанные запчасти
Шаг 1 Motherboard  ¶
Use a spudger to pry the microphone cable off the motherboard.
Шаг 1 Motherboard  ¶
  • Use a spudger to pry the microphone cable off the motherboard.
  • Pry from underneath the cable.
Шаг 2  ¶
Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector. Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
Шаг 2  ¶
  • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
  • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
Шаг 3  ¶
Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector. With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
Шаг 3  ¶
  • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
  • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
Шаг 4  ¶
Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector. With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
Шаг 4  ¶
  • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
  • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
Шаг 5  ¶
Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector. With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
Шаг 5  ¶
  • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
  • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
Шаг 6  ¶
Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable. With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
Шаг 6  ¶
  • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
  • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
Шаг 7  ¶
Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
Шаг 7  ¶
  • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
Шаг 8  ¶
Remove the screws securing the motherboard to the upper case:
Шаг 8  ¶
  • Remove the screws securing the motherboard to the upper case:
  • A single 2.5 mm silver Phillips screw
  • Four 3.7 mm black Phillips screws
Шаг 9  ¶
Deroute the microphone and antenna cables through the slot in the motherboard.
Шаг 9  ¶
  • Deroute the microphone and antenna cables through the slot in the motherboard.
Шаг 10  ¶
Rotate the motherboard off the lower case. The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
Шаг 10  ¶
  • Rotate the motherboard off the lower case.
  • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
Шаг 11  ¶
Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector. With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
Шаг 11  ¶
  • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
  • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
  • The motherboard is now free from the upper case.
