Помощь
Brother PT-1010 Keyboard Replacement
Лучше введение
Лучше введение
Улучши это руководство, заполнив или отредактировав его.
This guide will show you how to remove and replace the keyboard of your Brother PT-1010 label maker.
  • Автор: Haley Sweet
  • Времени уйдёт: 5 мин.
  • Сложность: Средняя
Инструменты
Шаг 1 Remove Back Cover  ¶
Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
Шаг 2  ¶
Remove batteries, cassette tape, and cutter blade.
Шаг 2  ¶
  • Remove batteries, cassette tape, and cutter blade.
Шаг 3 Remove Screws  ¶
Use a phillips size #00 screwdriver to unscrew the 5 corner screws circled in the picture.
  • Use a phillips size #00 screwdriver to unscrew the 5 corner screws circled in the picture.
Шаг 4 Separate Device  ¶
Separate the top of the device from the bottom. Be very cautious when you separate the device, there is a ribbon attaching the top to the bottom.
  • Separate the top of the device from the bottom. Be very cautious when you separate the device, there is a ribbon attaching the top to the bottom.
Шаг 5 Remove side panels  ¶
Remove the two black side panels. They will easily fall out so just move them to the side until you are putting your device back together.
  • Remove the two black side panels. They will easily fall out so just move them to the side until you are putting your device back together.
Шаг 6 Pull Ribbon Out  ¶
Using your index finger and thumb, pull out the golden ribbon from the green circuit board. Using your index finger and thumb, pull out the golden ribbon from the green circuit board. Using your index finger and thumb, pull out the golden ribbon from the green circuit board.
  • Using your index finger and thumb, pull out the golden ribbon from the green circuit board.
Шаг 7 Remove Screws from Circuit Board  ¶
Use a phillips size #00 screwdriver to remove the two screws, circled in red, from the green circuit board.
  • Use a phillips size #00 screwdriver to remove the two screws, circled in red, from the green circuit board.
Шаг 8 Remove Circuit Board  ¶
Carefully remove the green circuit board by pulling it straight up. Be careful not to break the LCD cable ribbon that connects the circuit board to the device.
  • Carefully remove the green circuit board by pulling it straight up. Be careful not to break the LCD cable ribbon that connects the circuit board to the device.
  • The ribbon is very fragile so be careful to break it when pulling up on the circuit board.
Шаг 9 Peel Off Rubber Keyboard  ¶
Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device. Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device. Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device.
  • Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device.
