Помощь
JIAYU F1 Power Button Replacement
Replace the power button on your JIAYU F1.
  • Автор: Nicole
  • Времени уйдёт: 15 - 30 мин.
  • Сложность: Средняя
This guide will provide instructions on how to replace the power button.
Разделы
Инструменты
Шаг 1 Remove the Interior Midframe Assembly  ¶
With the phone lying face down, remove the nine 3 mm Phillips # 00 screws from the midframe. Gently run a plastic opening tool down along the left and right sides of the phone to separate the black midframe assembly from the silver display casing. Carefully remove the midframe assembly from the display casing by pulling up and away from the phone.
  • With the phone lying face down, remove the nine 3 mm Phillips # 00 screws from the midframe.
  • Gently run a plastic opening tool down along the left and right sides of the phone to separate the black midframe assembly from the silver display casing.
  • Carefully remove the midframe assembly from the display casing by pulling up and away from the phone.
Шаг 2 Removing Power Button  ¶
Locate the silver power button at the top of the phone. Use the precision tweezers to slide the power button out of the groove. When replacing the power button align the flat side of the button to the silver edge of the display with the rounded edge facing the black frame.
  • Locate the silver power button at the top of the phone.
  • Use the precision tweezers to slide the power button out of the groove.
  • When replacing the power button align the flat side of the button to the silver edge of the display with the rounded edge facing the black frame.
